Whats this?
49 Cubber!
01-02-2004 13:28:15
third party image
and how much should I offer for it,busted manifold but no water got in the engine,so its not locked up.seemed to shift through all the gears fines,I couldnt find a plate anywhere,so where should the serial number plate be?
caseman-d
01-02-2004 19:45:07
 Re: Whats this? in reply to 49 Cubber! , 01-02-2004 13:28:15
It's a Case S, looks like a 1942 model. Where is it located at, it looks familar. Might check engine flange by air cleaner for serial number. See them bring 800-1500 depending on the location. Does that have the multi-fuel manifold or just a regular manifold.
caseman-d
49 Cubber!
01-03-2004 05:44:17
 Re: Re: Whats this? in reply to caseman-d, 01-02-2004 19:45:07
Contact me offline and Ill tell ya where it is!I don know anything about a Case,just dang ole Farmalls.I am wanting to expand my knowledge a little and have something different in my collection.I may buy it,I may not.The owner origianlly wanted 2500 for it,until I noticed alot of small problems with it.I got him down to 800 and he said he maay go lower,hed have to think it over.I have gone back over there yet,but am this morning to check the serail number.Are parts hard to get for this thing?Thats going to be a major selling point to me.I noticed after looking at some pic of others and a few more I made that the air filter is missing.The carb is in a box but looks like I can rebuild it.the manifold as I said is busted,but I guess with the can on the pipe,and where the hood is positioned,no water got in the engine,at least as far as I can tell.The engine isnt locked up but was kinda hard to turn with the crank,and the starter was missing,but the generator and the wiring is still there.
Larry
01-02-2004 14:42:00
That is a Case S. Thge serial number is on a plate on the dash behind the steering wheel. It is also on the engine flange on the left side where it bolts to the transmission.
joel
01-02-2004 14:41:53
Looks like a Case S model. There serial number on my case sc is on the motor frame on the left hand side as you are sitting on the tractor between where the motor mounts to the transmission. It usually reads up and down. Take a wire brush with you as it can sometimes be tough to read.
Joel
