VAC distributor make?
ff316
01-02-2004 11:59:01
I stopped at TSC to pick up a set of points/cond/rotor for my 49 VAC. They had two sets for Case, one for Autolite distributor and 1 for Delco. My VAC is about a mile back through a muddy field in a barn right now, What make were VAC distributors or do I need to go back there and look? Thanks!
Fireman in KY
Joe (Wa)
01-02-2004 17:20:29
 Re: VAC distributor make? in reply to ff316, 01-02-2004 11:59:01
Parts manual lists it as Autolite IAD6003-2F and that is what I have on a '53, (well, actually it is on the 311B and the 311b is on the VAC).
Joe
ff316
01-02-2004 12:49:41
I'm convinced. I'll get the Autolite, and if it turns out to be wrong at least I'll get 5 bucks back. Thanks!
Fireman
Rigidharley
01-02-2004 12:10:27
I have 5 VAC'S down here and they all have Autolite dist in them, Franks makes six, might take a chance on it.Hope this helps. Jim
F-I-T
01-02-2004 12:00:34
FF:
Mine is an Autolite. Don't know if that helps you.
Frank
ff316
01-02-2004 12:07:16
 Re: Re: VAC distributor make? in reply to F-I-T, 01-02-2004 12:00:34
I'm guessing mine is Autolite, the Delco set is $5.00 cheaper :)
Fireman
F-I-T
01-02-2004 12:47:29
 Re: Re: Re: VAC distributor make? in reply to ff316, 01-02-2004 12:07:16
Well, there you go!
You know yours won't be the sheaper one.
Ha!
