Case 990
Woody
01-02-2004 11:36:34
We bought a Case 990 at an auction.
It has a trasport lock on the rear arms.
Need to know what postion the lock arm lever needs to be in when we want to use the arms. Thankyou
James
01-02-2004 13:52:03
 Re: Case 990 in reply to Woody, 01-02-2004 11:36:34
Down is engaged, up/vertical is engaged. You may have to lift the arms manually above their normal up position to get the arms locked. You can also do this by pulling the control lever rearward against the spring pressure to the 'select' position. This temperarily lifts the arms higher than the normal up position.
