Hood prop on VAO question
Ted in Sacramen
01-02-2004 07:26:17
The hood on my 1948 VAO has a bracket screw and wingnut which I assume held the hood prop. What was it? where does it rest? and did it have a retainer somewhere for when not in service? The frustration broken golf shaft I use now is functional but a constant reminder of my inabilities. Thanks
F-I-T
01-02-2004 07:33:19
 Re: Hood prop on VAO question in reply to Ted in Sacramento, 01-02-2004 07:26:17
Ted:
If it's the same as the prop on a VAC, it is a piece of hickory, that rests against either the valve cover, or one of the fuel tank straps, depending on how high you need to raise the hood. To retain it, you just tighten the screw so it binds a bit and it will stay up against the inner hood for storage.
There is one very faint photo in the service manual of the prop. I can get a picture and measurements later if that would be helpful.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
Ted in Sacramento
01-03-2004 07:51:41
 Re: Re: Hood prop on VAO question in reply to F-I-T, 01-02-2004 07:33:19
Thanks Frank, dimensions, especially length, would help to get it close to original. Not a lot of hickory out here but I'm sure Oak would do OK. Thanks again.
