late VAC hydraulics
Jim
01-01-2004 19:04:33
I have a 1954 VAC-14 with the optional remote cylinder control valve, and I need the coupler bracket and clamps. Anyone out there have one for sale or have one for a pattern?
Rigidharley
01-01-2004 21:51:34
 Re: late VAC hydraulics in reply to Jim, 01-01-2004 19:04:33
Hello Jim, My little 1951 VAI has a remote cylinder control valve on it which can be used with or without the eagle claw 3 point system. It is bolted directly to the torgue tube just behind the flat belt pulley mount,and the handle for it is mounted up on the dash. Does this sound like what your looking for? If so I can try and help get You a pic of this system. Jim Edmonds
mike's 600
01-02-2004 06:23:34
 Re: Re: late VAC hydraulics in reply to Rigidharley, 01-01-2004 21:51:34
Hey, checked my parts book on a Vas, different number. I thought it might be the same as the Vac-14.I have a Vas, and a couple of Vac's part tractors, no luck on the gear.
Check with Don L.507 433 0073
Mike
Jim
01-02-2004 07:15:06
 Re: Re: Re: late VAC hydraulics in reply to mike's 600, 01-02-2004 06:23:34
Thanks guys, basically what I'm looking for is a blueprint or drawing of some sort for just the coupler holder. I think your VAI is the same thing as my VAC-14, but have to check my parts books. Thanks
