information on a 1490 case international
neil campbell
01-01-2004 15:35:30
Sounds stupid but can't find where you put in the oil....not in manual. Also have a leak in the steering colum, must be power steering fluid also lots of play in the steering wheel....leaking fluid all over the place.....any help?? Got a manual but lots of things are not listed in it. Tractor is a high profile with cab.
kyhayman
01-01-2004 16:48:10
 Re: information on a 1490 case international in reply to neil campbell, 01-01-2004 15:35:30
Power steering pump and reservoir are located on the right side of the engine. Look at the right side of the tractor and find the fuel transfer pump, just forward of that is round pump reservoir of which the pump is integral. Pump runs off a timing gear. Should be a hex head bolt in the reservoir (seems like 1-1/8th, I usually use an adjustable). Add here.
