LA kill switch
JAY
01-01-2004 14:07:44
I have a 1950 LA it came with no kill switch . Is ther a grounding post on the magnito somewhere ?
robert
01-01-2004 15:51:19
 Re: LA kill switch in reply to JAY, 01-01-2004 14:07:44
At rear of original mag is a swinging tang,undo that and under cap you should see a couple of contacts that should make a ground-out when lever for spark advance is pushed all the way ahead.Mine never worked when I got it ,it just needed a gentle bend on the contactor to cure .
Dr Cy Kosis
01-01-2004 14:52:48
If it still has the big eagle mag, there is a "kill switch" is built into the mag. When you retard the mag all the way it should ground itself out.
todd hamilton
01-01-2004 17:43:06
 Re: Re: LA kill switch in reply to Dr Cy Kosis, 01-01-2004 14:52:48
I sort of understood that LAs ran "forever" so what seems to be the problem?:^)
