Case CC
CJWinIL
01-01-2004 10:52:10
I have a case ccwith serial number A-4591, what year was this manufactured?
CJW
Casenut
01-01-2004 15:35:00
 Re: Case CC in reply to CJWinIL, 01-01-2004 10:52:10
The number you have posted is a casting and part number (I'm guessing the valve cover A-4791) I am interested in knowing the year of your tractor also. Please let us know what you come up with.
Brian in Ohio
01-01-2004 10:57:58
If we had a serial number, that would help. It should be on the tag on the tool box, or stamped on the engine, next to the fuel tank, on the magneto side.
If there are 6 digits, in ther serial number, take the first and fourth digits, put them together, and subtract 3.
Example: 300916 = 39 - 3 = 36 which means 1936
If there are 7 digits, take the first two digits, put them together, and subtract 4
Example: 4236823 = 42 - 4 = 38 which mean 1938.
Hope that helps...
Dr Cy Kosis
01-01-2004 12:27:40
 Re: Re: Case CC in reply to Brian in Ohio, 01-01-2004 10:57:58
Seven digit serial numbers begining with less tha 42 use the old six digit formula. In 36 and 37 the production exceeded the number capacity that would fit into the formula. They had to add a digit in the middle to accomodate the higher production.
42x0xxx would be a 38 model using the 42 up seven digit formula, while 40x0xxx would check good for a 37 rather than a 36.
For the six digit numbers (and 7 digit less than 42):
The first fourth digits represent the year model while the remaining digits represent the actual sequence of that basic model of machine.
Example:
My L, L351234 would be 3xx2xxx for the year code, or 32-3 for a '29 model and was x51x34, the 5,134th L based tractor built that year.
My C, C308720 would be 3xx7xx or 37-3 for a 1934 model and was x08x20, the 820th C based tractor built that year.
I'm sure the 38 to early 53's use a very similar system but best I can tell the sequence numbers no longer differentiated between models but sequenced all the models together.
Hypothetical example: DC4815432 would be a 1948 DC and was the 15,423nd tractor produced by Case in that year.
After Jan 1 53 they went to block sequence numbers.
Whew!
I hope I didn't commit too many errors in all this so it can be understood a little bit.
