C.Amick would You know by chance
Rigidharley
01-01-2004 08:33:42
Hello, again. Would You have or know anyone around local that might have a 67 tooth bull gear for a VAC-14? I have one in my garage that I'm restoring for a freind of mine,well after a little close inspection of a noise in the rear while turning the axles I found a tooth broke off on the left rear bull gear.And I would really rather replace it versus welding the tooth back on.So I thought I would ask if You might have one or know where one is around here since your pretty close by. Thanks Jim
Rigidharley
01-01-2004 15:14:40
 Re: C.Amick would You know by chance in reply to Rigidharley, 01-01-2004 08:33:42
Hey, Thanks a million guys I will check with these places and see if they can help me out. Shame is I have 2 good bulls done here still in the housing but they have 65 teeth and I need 67 teeth. Thanks guys Jim
mike's600
01-01-2004 13:46:12
Hey send me a part number for the bull gear. I have several that i'am parting out.
Thanks Mike
Rigidharley
01-01-2004 16:38:26
 Re: Re: C.Amick would You know by chance in reply to mike's600, 01-01-2004 13:46:12
Hello Mike, I got the bull gear out of the VAC-14, only # on the gear itself is the #4 stamped in the machined surface along the edge of the teeth,so I checked my case parts catalog and the case # for the gear I need is VT5467.Hope this helps You out. Thanks Jim Edmonds
martin in De.
01-01-2004 09:31:50
W C Littleton in Laurel De. has a VAC 14 that is being parted out,the transmission is already gone.Regards martin
