600 big LP
mikes'600
01-01-2004 05:46:14
We got the 600 unstuck, installed a new points and condenser set,and she runs good!
It is poping back through the intake under load, but getting better the more we run the 600.
What has been the experience of the board? Will it get better, or will i need to pull the heads?
Thanks
Roger
01-01-2004 08:24:02
 Re: 600 big LP in reply to mikes'600, 01-01-2004 05:46:14
I agree with Tom, I reset the valves on my 930 gas the other day, didn't seem like I changed much on the tappet gap but it sounds better now, only problem is there isn't any snow anymore to try it on the blower
caseman-d
01-01-2004 07:59:43
Congradulations on getting it running, think I would try adjusting timming, fireing order, and make sure the dist advance is working correctly. Might have to check valve clearance and check for a sticky valve. If it was gas I would say poor some transmission fluid down thw carb but don't know if you can on a lp. Been told ATF will losen up any carbon deposits. Hope this helps
caseman-d
