Rubber seat spring rivets?
G. L. Grumpy
12-31-2003 18:55:05
WAs looking at my SC with newer seat with rubber tork spring. I had to knock out rivets to get the sides off original. I bought bolts to put it back together, but heads won't clear the space between hardware when seat goes down. It's about a 5/16" hole. Pop rivets go to 3/16, far as I know. I don't wanna mess with steel pounded rivets. Any of you replaced these? with what? I'm gonna try 1/4" flathead bolts, so head sinks in hole some, think it will clear, but not so sure looks will be good enough! I now have phillips Panheads, too big!
Glenn FitzGerald
12-31-2003 19:30:49
 Re: Rubber seat spring rivets? in reply to G. L. Grumpy, 12-31-2003 18:55:05
It's been so long since I took my original apart. If I remember right they were factory with rivits, right? I know I rivited mine quite easily. I installed a used one. That was 15 years ago. Time to replace. This time with a new one. It will be rivited.
Jim
01-01-2004 10:04:07
 Re: Re: Rubber seat spring rivets? in reply to Glenn FitzGerald, 12-31-2003 19:30:49
I got some for my VAC-14 from the hardware store, I might have some extra's I could send you. How long are yours?
