Profile for Case VAC 5052904
Harry
06-12-1999 18:33:24
Hi, You CASE crazies ! Friend just obtained Case tractor with VAC5052904 on the dash ID. Plate. Can some one give me a profile? I've checked a case site, and the # indicates a 1946. Can some one give a more in depth profile; ie. hp, uses, good / bad points, etc? Thanks a bunch!!!
Dug G.
06-12-1999 19:50:11
 Re: Profile for Case VAC 5052904 in reply to Harry, 06-12-1999 18:33:24
Well, your friend just obtained one of the nicest Case tractors made. They produce 19.04 brake hp and 15 drawbar hp, in idea conditions. A lot of people here in Ohio use them with belly mount finishing mowers, 3pt mowers, cultivators, front end loaders, and rear blades. The good points are that there still easy to get parts for, and there compact and require only a little daily and seasonal maintenance. On the bad side, well, i haven'thad to many problems with either of ours, luckily!
Dug G.
06-12-1999 19:50:09
