case gauge set
JCMZ71
12-30-2003 22:26:24
I was going through grandpa's stuff and found a brand new gauge set (single glass with fuel,oil,mph,hours,rpm,temp, and amps trimed in chrome) but i don't know what model it goes to. Can anyone help? Oh ya it's new with no hours on it.
JCMZ
01-03-2004 08:16:36
 Re: case gauge set in reply to JCMZ71, 12-30-2003 22:26:24
search for case tractor gauge on ebay thanks for your patience
JCMZ71
01-01-2004 13:27:25
Well I'm putting it on Ebay starting saturday.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2451943700 thanks for all your input
JCMZ71
12-31-2003 20:25:44
Well thanks for the great info. Now I know it's for 530,730,830,630,630C,and 530C according to the P.T.O. #s
I will either put it on Ebay or something in the next couple days once I figure out a starting bid. If I knew how to put a pic on this then I would. Or if you want leave an e-mail add and I'll send some pics. Thanks John
Roger h.
01-01-2004 07:55:52
 Re: Re: case gauge set in reply to JCMZ71, 12-31-2003 20:25:44
Apparently that guage set has a black face and those are the tractors it was used on, but if the face is brown it was used on the '56 &'57 300's and 200's and other earlier models, that's the one I need. I went to 275.00 on a usedone on e-bay and it was rusty. Not a good buy, you can start it at anything because iot will bring several hundered I'm sure. Roger
Lincoln
12-31-2003 20:42:59
Might as well start it at $1.00 because it is going to bring good money. I saw a used one a while back on E bay. I stopped bidding at $100. Didn't see what it ended up bringing.
Chad Grant
12-31-2003 19:02:11
If this guage set is for a 530 CK, I need it Chad 520-578-3927
JCMZ
01-03-2004 18:51:35
 Re: Re: case gauge set in reply to Chad Grant, 12-31-2003 19:02:11
check it out on ebay 2451943700 ....thanks
Scott Flynn
12-31-2003 13:48:24
If you can't supply pictures, it could help narrow the field by describing which way the tachometer reads (the later models read left to right or CW, but the 300 and 400 read right to left or CCW and are on the right side of the face). Hope this helps! If it's the right model, I would be interested in it as well!
Mark
12-31-2003 13:13:22
Do this..... take a couple of good pics and gather all the info you can about it such as PTO speed(s), color approximate size, etc. Post the pics & info here and place it on this site's auction board. Then notify the users here that it is up for auction. I think you will get a fair price and a deserving Case nut will own it.
Don L.
12-31-2003 12:47:31
I volunteer to pay to much. I would like to use it as a pattern to make a reproduction, 507 433 0073 am best
Steve-IA
12-31-2003 09:50:49
A photo would be great. You may consider ebay & let us know it's there. I think Case Poor is right, it's worth some bucks. Our 830 also wants a new face:).
Steve
JCMZ
01-03-2004 18:50:52
 Re: Re: case gauge set in reply to Steve-IA, 12-31-2003 09:50:49
case poor in pa
12-31-2003 06:16:08
sounds like you got 1 HOTTT item there if ya know what i mean. id be interested in it along with 17,000 other guys
John
12-31-2003 05:16:27
It sounds like it might be for a tractor like a 730, 830 case. Are you interested in selling it?
JCMZ
01-03-2004 18:48:21
 Re: Re: case gauge set in reply to John, 12-31-2003 05:16:27
I put it on ebay check it out search for case tractor gauge and you'll find it...thanks
Klyde
12-31-2003 04:25:26
Need to know the following, unless there is a part # on the box.Brown or black background. Oil prressure range. What RPM is marked PTO speed.
JCMZ71
01-03-2004 08:11:22
 Re: Re: case gauge set in reply to Klyde, 12-31-2003 04:25:26
Roger H
12-31-2003 18:38:35
That sounds like the dash used on case tractors starting in the middle fifties and later. Early ones had a brown face later ones black. Would be a very good item to sell on e-bay. Would be interested myself. Ph.301-223-9005
