Case 210B transmission problems
Randy Peterson
12-29-2003 10:34:37
I am looking at a Case 210B with a loader. It wont stay in gear. You have to hold it in to go I was wondering if there are any common problems with this. Also wondering what the going price is on this model. The engine Seems to run real good.
Thanks
Randy Peterson
Steve Schmittgens
12-29-2003 14:20:06
 Re: Case 210B transmission problems in reply to Randy Peterson, 12-29-2003 10:34:37
Randy,
You're not providing enough info, call me @ (314) 966-6692 & I'll help you diagnose the problem. I worked for Case for 25 years & I know the quirks of these machines.
Steve
Chuck MA
12-29-2003 12:22:04
Had the same problem with a 310 utility would pop out of low. Needed to replace O ring, part was not expensive, but you have to split the tractor to fix the problem. If you can do it yourself there is not a big expense. Paying a mechanic to do it run into quite a bit of money. I had a professional do it, and while it was split had him replace anything that needed to be replaced. When I finally got the tractor back all fluids and filters were new, tranmisssion was in top shape, and the engine runs perfect and I have not had a major problem in three years that I have owned the tractor. This tractor is still 6 volt and starts every time no matter how cold or wet.
Thanks Chuck
Mike Johnston
12-29-2003 10:46:14
Is it the low/high range that is popping out? Mine pops out of low if I happen to be going downhill. Otherwise, its a great little tractor. Couldn't give you an idea on price--inherited this one.
Mike Johnston
Steve Schmittgens
12-29-2003 14:28:57
 Re: Re: Case 210B transmission problems in reply to Mike Johnston, 12-29-2003 10:46:14
Mike,
On those machines if you have that problem or if it pops out when you let off the throttle quickly it's usually the synchronizer on the input shaft. Call me @ (314) 966-6692 if you have any questions.
Steve
