Manifold heater repair---?
Roger (Va.)
12-29-2003 06:55:53
I have a Case 430 diesel that does not start when below 35 degrees. Cranks. I do not use ether, but may have to resort to.
The manifold heater coil has broken lose at the end which is attached to the plug. My case dealer cannot get a new one. Someone on this site said that they had welded one of these and it was successful.
how is welding done? type of welder and rod used?
Has anyone found this part or a substitute somewhere?
Note-- tractor has block heater, but 110 volt juice is not available.
Thanks in advance.
Jcmarleau
12-30-2003 19:09:56
 Re: Manifold heater repair---? in reply to Roger (Va.), 12-29-2003 06:55:53
Hi Roger if you didn't get any luck with the repair i have a few good used one. my e mail is [email protected]
John Saeli
12-29-2003 18:49:31
Hey Roger: Put that ether can away! I've welded those coils back with my old 180AC welder. Any other welder would be better. A-C used the same heater, but they don't furnish it either.
Roger (Va.)
12-29-2003 20:00:26
 Re: Re: Manifold heater repair---? in reply to John Saeli, 12-29-2003 18:49:31
Thanks for the reply
what type of rod did you use?
any special welding techniques?
I have an ac/dc welder and a carbon arc torch. I have never brazed, but I guess I could learn.
