Well, the good news is������The VAC started under its own power this evening, and there are no bad really things to report. The bad news is..... .. I did burn all the pretty paint off of the muffler, so it will have to get a coat of Eastwood Stainless High Temp (that�s what�s on the manifold, and it seems to be staying on pretty nice so far). I ran it all totaled for about 90 minutes. I set the idle at a little above normal (she�s still a bit tight) and the high end I set with my handheld electronic tachometer on the PTO at 525. The timing is just a few degrees advanced. I�ve looked and I�m not sure I am reading the book correctly. Anyone know what it should be at high speed with a light? I see 4 BTDC one place in the service manual. I restarted it several times, and it groaned but fired. I even crank started it a couple of times. The Eagle hitch goes up and down and stops where you set it, and by golly, it even charges in the three positions (nearly 20 amps!). Oil pressure is running about 15 PSI on high speed, and probably around 7-10 at idle, but it�s really hard to tell with a 40 pound gauge. I wish I could find a Case gauge that read in the old graduations. I want to thank everyone for helping me get it this far, but I�m afraid I might leave out someone�s name, so please understand that this is a big THANK YOU to everyone who helped me find parts, specifications, paints codes, and offered words of encouragement. I�m still working on the final piece of tin, which is the front grill and it is in pretty tough shape, so it might be a while before you�ll see final pictures. But I promise that I�ll get a final report together to post here and on my site. Again, thank�s to everyone. Frank-in-Tallahassee 70D // 855 // VAC [email protected]
