clutch not engaging DB 885
Bill Finnegan
12-28-2003 16:43:22
I have a Case 380CK which was made by David Brown.
Previous owner replaced clutch approx 4 years agoand unit used very little.
While repairing Driveway the other day unit was working fine and gave no warning of a problem. Clutch sudddenly went out of adjustment barely able to move tractor.
Removed inspection plate and made adjustment. No signs of any fibers in bell housing.
Attempted to adjust freeplay and it began to shift and grab a little better.
Could the clutch petal have loosened on the shaft? If so how could I check and adjust the petal? Any help would be greatly apprerciated.
fire0307
05-05-2005 19:06:53
 Re: clutch not engaging DB 885 in reply to Bill Finnegan, 12-28-2003 16:43:22
i also have a 380 ck. the other day it was like it locked up and wouldnt go into reverse, and the forward/reverse shifter wouldnt shift. the engine would bog and stall. i freed up the shifting forks and it still doesnt run. does this sound like your problem and what can i do.
rod
12-29-2003 06:15:48
send me an email I will scan the info from the manual for you on the clutch.
regards
rod
[email protected]
