580ck weak boom swing
dt962
12-28-2003 14:54:30
I recently bought a 67 model 580ck backhoe. All the controls work on the hoe, but the side-to-side swing controls only have enough power to swing the boom if it is off the ground. It does not have enough power to push loose dirt from side to side to fill in a trench. Is this normal for this model or is something wrong with the hydraulics? Thanks.
Steve Schmittgens
12-29-2003 14:39:47
 Re: 580ck weak boom swing in reply to dt962, 12-28-2003 14:54:30
DT,
Call me @ (314) 966-6692, I can give you a few ideas on what to try. I worked for Case for 25 years & I know what makes these things tick.
Steve
rod
12-29-2003 06:17:59
I have the shop, operators, and parts book for the 580CK to sell let me know if you need any going cheap.
[email protected]
Max
12-29-2003 05:36:56
That's pretty normal, otherwise you would be replacing the dipper pin or something else on a normal basis. The backhoe was not designed to backfill with the side of the bucket.
gm
12-28-2003 15:14:30
Prob the swing cylinders are leaking internally. Or maybe the control is not opening up all the way. -Greg
