Power Lift wont GO Down
Homer Barrera
06-10-1999 08:09:30
I have a Case 1370, and I am having problems withe the power lift, I thought the Hytdaulic Filters were dirty, but I replaced them and the Arms still will not go down. They are in the up position and will move down about 1-2 inches. Any suggestions??
don ruscha
06-10-1999 17:22:47
 Re: Power Lift wont GO Down in reply to Homer Barrera, 06-10-1999 08:09:30
check under the platform in front of the seat there is a plate. take it off & under it is the controll lever that the cable that controlls the lift hooks to. see if when you move the lever the controll moves, it could be your cable is broken or like my 1070 the roll pin that pins the lever to the controll shaft under the seat broke. the best of luck.
Jim
06-10-1999 10:44:32
Check the draft linkage out under the tractor.
