Frank In Tallahasse Have you started your Case Vac
Nicholaus Sowde
12-27-2003 19:08:50
Frank In Tallahasse Have you started your Case Vac yet? Did you rebuild the hole engine or what? I have two Case Vac tractors. I took the oil pan off one of them and on two of the manin bearing holders you can move them a little. One is worse than the other. About how much did it cost to rebuild the engine if you rebuilt it. Thanks
art francis
12-28-2003 18:18:36
 Re: Frank In Tallahasse Have you started your Case in reply to Nicholaus Sowder, 12-27-2003 19:08:50
Nick
I just completed mine, new rings, all new bearings, rebuilt water pump, complete new clutch, repaired radiator, a new front tire and misc oil/plugs/filters and spent $1500.00 Not too bad for a new motor.
Art
F-I-T
12-28-2003 04:54:28
Nicholas:
I haven't started it yet. Anyday now, I hope. I honed the cylinders and replaced the rod bearings and rings. The mains seemed pretty tight. The head required lots of work though (all springs, valves, seats, grind, surface grind).
I would think if you have losse mains, you would probably have to remove the crank and have it ground.
I think you can get a complete piston and sleeve kit for a VAC for around $499.
Frank
Nicholaus Sowder
12-28-2003 06:51:11
 Re: Re: Frank In Tallahasse Have you started your in reply to F-I-T, 12-28-2003 04:54:28
It is not the main bearings it is the rod bearing on two of them. I typed the wrong thing. Thanks
