Case 580ck
R Smith
12-27-2003 14:45:05
Looking at a 69 model 580 very good condition.But
it wants to jump out of forward gear unless you hold the shifter forward and use low range. Then it stays in gear But you have to baby it to get it moving otherwise it will jump out. Any ideas?
Steve Schmttigens
12-29-2003 14:46:51
 Re: Case 580ck in reply to R Smith, 12-27-2003 14:45:05
Hello,
Problem is the Synchronizer & the gears around it are worn & the edges of the teeth are rounded.
Call (314) 966-6692 if you have any questions.
Steve
Jim B.
12-31-2003 19:05:43
 Re: Re: Case 580ck in reply to Steve Schmttigens, 12-29-2003 14:46:51
Steve:
I've noticed your comments on several earlier Posts about the 580CK > you seem to know the machine after working on them for 25 years. But I have a question similar to Mr. Smiths! My 580 CK jumps out of first gear but only when loaded heavy, such as pushing the loader bucket hard forward to fully fill it. I replaced First gear on the tranny mainshaft even though it did not have rounded teeth nor did it's mate on the countershaft. There are no syncro's in my transmission. The fork was not spread, the bearings are tight, the detent spring(s) in the shift mech seems tight. What would you diagnose, as it still pops out, but not as easy. Mine is a Power Shuttle, Diesel.
