LP head and MW high dome pistons
bll
12-26-2003 17:32:15
Any body put L p Head on DC with M&W raised dome pistns Will they clear as the dome is high and the LP head fits close How about too much compression???
dctom
12-26-2003 17:51:16
 Re: LP head and MW high dome pistons in reply to bll, 12-26-2003 17:32:15
I have heard itwont work but i am going to try putting one on mine soon will post how it works dctom
bill
12-26-2003 19:38:53
 Re: Re: LP head and MW high dome pistons in reply to dctom, 12-26-2003 17:51:16
Thanks Tom I will be looing for the results If you think of it e mail me the results as I might miss them on forum Again Thanks Bill
mikes600
12-27-2003 13:29:07
 Re: Re: Re: LP head and MW high dome pistons in reply to bill, 12-26-2003 19:38:53
You will have a clearance problem using the lp head. You need to use the gas head.I have a LP head on my puller, with flat top pistons, cut the head 100 thou.,and used a copper head gasket.This combo worked great for one year, beat alot a JD A's.This past year the A's came back stroked in the 600 cubic inch range. The DC fell back to 3rd 4th place.I need to add more cubes.Iwas pulling 2nd gear 4.0 mph 4000lbs & 4500 lbs.
