DC Clutch
Russell Dewsnup
12-24-2003 05:38:02
When I pull the hand clutch back on my DC it pops over center but the tractor keeps moving. If I pull back hard on the clutch lever the tractor will then stop. I also have to pull back hard to shift gears on engage the transmission. Is this a sign of a bad clutch or an adjustment that needs to be made. The tractor pulls strong and I have not had the clutch slip when working it. This is my first Case tractor so any help will be greatly appreciated.
MarkS
12-25-2003 10:45:53
 Re: DC Clutch in reply to Russell Dewsnup, 12-24-2003 05:38:02
Russell, You may want to adjust the brake on the belt pulley shaft a little tighter so that it will stop the tractor when you disengage the clutch. It may even need a new pad. You found a good first Case.
MarkS
dctom
12-24-2003 06:33:52
kinda sounds like you have it adjusted a little too tight, back off a few notches and see if that dont help
bill
12-24-2003 15:43:32
 Re: Re: DC Clutch in reply to dctom, 12-24-2003 06:33:52
Tom how many different flywheels are there for D C series I kow foot clutch is diferent than hand clutch lpto and hand lptp is different than standard hand cluth Also will hand lpot clutch facing fit in foot clutch lpto???? hey have a good christmas Bill
DKase
12-25-2003 17:56:51
 Re: Re: Re: DC Clutch in reply to bill, 12-24-2003 15:43:32
There is the old clutch that is the same as the CC used on the early D series. Then there were 2 different styles in the non live PTO machines. The hand clutch LPTO is simular to the latest non LPTO, but the spline in the disk is much bigger so there is room for the PTO shaft to fit through. All the hand clutches are 11". The foot clutch is 12". They are very prone to breaking the pressure plate in half. I have welded several back togather. I hope this answers your questions. If I am wrong about something I'm sure someone will straighten me out. Merry Christmas and Happy New Year!
Klyde
12-24-2003 10:23:13
Check in the clutch housing drain and see if there are pieces of spring in there. there are springs on the pressure plate to pull it away from the clutch plate when you disengage the clutch. If they're broken the oil will make it stick to the clutch plate.
