block heater
mike
12-23-2003 16:41:33
A few of you have been kind enough to steer me in the direction of a tank block heater. My question is when I look at my David Brown 1210 is where can I run the lines from the block? It may be a rudimentary question but any help is appreciated.
Elmer
12-24-2003 13:48:35
 Re: block heater in reply to mike, 12-23-2003 16:41:33
I usually drill a hole in the left side of the head just below the thermostat. Opposite the temperature sender switch. I used to Tee into the sender switch and plumb the tank heater in there. Tap it out to 1/4pipe thread and an auto supply store can get you another nipple just like what is supplied with the tank heater.
SHeiserman
12-23-2003 19:27:10
Elmer is the one you need to talk to. On my 830, there is a threaded opening on the block, and one down by the oil filter ass'y. I just mounted the heater where it was out of the way and secure, and ran the heater hose from the lower opening, thru the heater, then back up to the opening in the block. Get Elmer's attention and he'll be able to walk you through it.
Mike
12-24-2003 10:28:50
 Re: Re: block heater in reply to SHeiserman, 12-23-2003 19:27:10
Thanks! I found the lower plug (3/8) down by the oil filter. Where on the block/head was the upper one? The more specific the better!
Thanks again!
kyhayman
12-23-2003 17:26:17
I like the freeze plug on the left side in front of the oil filter.
Thad
12-23-2003 16:50:22
I put them in the block in the freeze plug instead of the tank type. Thad
