Voltage regulator
Lucas
12-23-2003 06:41:04
Could somebody tell me how to hook up a voltage regulator in place of the cutout relay on my VAC. Thanks
Klyde
12-27-2003 09:45:51
 Re: Voltage regulator in reply to Lucas, 12-23-2003 06:41:04
Never gave this much thought. To hook up the regulator, the wire that goes to your light switch is no longer used, but that terminal on the generator is the feild terminal for the regulator. Other terminal that went to the cutout is the Armature or GEN conection on the regulator. Wire that went from cutout to ammeter hooks to battery terminal of regulator. That should work.
Alvin n Ms.
12-23-2003 10:24:57
Link
Larry S
12-25-2003 15:09:47
 Re: Re: Voltage regulator in reply to Alvin n Ms., 12-23-2003 10:24:57
Polarization, as the above reply alludes to, is not your problem. Your generator uses a 3rd "adjustable brush, that you set internally to control your charging rate. Your regulator simply turns the field current off and on. You need the generator to match the regulator. The gen off an SC or DC should work, the brackets may have to me adjusted. I would strongly suggest you upgrade to 12 volt GM alternator, as described in the tech part of this web site. My VAC converted very easily, my SC is usable year round. Nothing wrong with 6 volts, just the hassle of finding a decent battery etc.
