VAC vs V manifold
John S.
12-22-2003 20:06:01
What is the differences on a V's manifold vs's an early VAC Manifold?
Don L
12-23-2003 05:11:31
 Re: VAC vs V manifold in reply to John S. , 12-22-2003 20:06:01
Believe it or not, it will fit to the head,it. The outlet is not in the right spot.I would think the linkage would run higher also on a V manifold. The V,VAC,300,300B,400B,500B,600B and the 430,530,470 ,570 take the same manifold gasket. That is a story in itself. But Gene is right,they are not the same "manifold".
Don L.
Gene Dotson
12-23-2003 03:41:38
Totally different engine. The V uses a Continental F124 flathead engine and VAC uses the Case 124 overhead valve engine... Gene
