Moving 930 front end
JW
12-22-2003 17:17:47
I got the center tube on my 930 freed up to slide in to 30 inch rows but am having problems getting the tie rods to slide in, does anyone have a secret to doing this. I need to move in 2 notches.
Roger
12-22-2003 20:43:31
 Re: Moving 930 front end in reply to JW, 12-22-2003 17:17:47
JW I used Liquid wrench penetrating oil on 1 side of my 930 gas. I wish I used it on the other side, I already had the one side moved when I tried the stuff, it made the pipe slide in SO EASY it made me mad that I didn't use it on the other side, just let it soak a few minutes.
Klyde
12-22-2003 19:33:43
Turbo's idea sounds good. I used to chain them to the deck of the roll back and use the winch to yank them appart.(stand back tho)
turbo
12-22-2003 17:36:38
If you have the assembly off, we submerge them in a hot tank. The water soaks in loosens them. The heat also helps. We have drilled the tube and tapped for a grease zerk and pumped them apart.
