VAC Engine Compression
HD IN ILL.
12-21-2003 13:41:31
I have a 1946 VAC AND WOULD LIKE TO KNOW WHAT THE ENGINE COMPRESSION SHOULD BE AND THE OIL PRESSURE. When it is running my gauge shows 15lbs. Any help would be great.
dctom
12-21-2003 14:43:18
 Re: VAC Engine Compression in reply to HD IN ILL., 12-21-2003 13:41:31
oil pressure is fine dont know about compression would think about 125#
HD IN ILL
12-21-2003 15:01:23
 Re: Re: VAC Engine Compression in reply to dctom, 12-21-2003 14:43:18
Thanks for the reply--I took a compression test and I'm right around 105 lbs on all 4. I haven't ran it enough yet to see how she going to do. She don't smoke so thats a plus.
Joe (Wa)
12-21-2003 17:19:19
 Re: Re: Re: VAC Engine Compression in reply to HD IN ILL, 12-21-2003 15:01:23
Normal engine oil pressure is 12-20 psi @ full rpm with oil @ operating temperature. If your gauge is reading right you are in good shape.
Assuming the 104 psi is dry cranking pressure, I wouldn't worry about it unless you need full power. I have seen them run very well with less than 80 psi. A spread of more than 10 psi is not recommended. Last time I checked mine it was 118-120 psi.
Joe
HD in ILL
12-22-2003 16:33:58
 Re: Re: Re: Re: VAC Engine Compression in reply to Joe (Wa), 12-21-2003 17:19:19
Thanks Joe for the info. I wish you and your family a very Happy and Safe Holiday. Thanks again. Butch
