David Brown timing/fuel pump RR
Jim Clancy
06-07-1999 18:19:09
Looking for timing marks so I can make sure they are set correctly before I pull the fuel injection pump.
this is on a 1969 880A modle with a 3 cyl. Perkins
Diesel engine.
Elmer
06-07-1999 19:24:19
 Re: David Brown timing/fuel pump RR in reply to Jim Clancy, 06-07-1999 18:19:09
The timiing marks are on the side of the mounting flange at one of the bolts. You can take the pump off with the engine in any position. The shaft inside has a master spline. lift out shaft and inspect the splines. A little wear can mean off timing.
