tire swaping
SLIDER
12-20-2003 12:00:02
Howdy again. I have an old case 800. I also have an old diesel that looks so similar the farmer I got them from had to paint gas and diesel on the fuel tanks so he wouldnt put the wrong fuel in them. I have the 800 gas one home to work on but the diesel still sits 2 hours away. The diesel is missing one rear and both front tires so I cant easily load that one on the trailer. My question to you is, how hard is it to swap a rear tire? I imagine they are charged so they must be incredibly heavy. Is there an easy way to do this? I need to get the old diesel out of his place by spring or he is going to give it to someone with a tractor scrapyard. The diesel motor needs rebuilding also, is it even worth bringing home or would it be cheaper for me to find another old running tractor for farming my hay? Several people have told me that the gas 800 casomatic isnt a good tractor for haying cause it will be jerky at pto speeds. Any input you can provide will be appriciated.
INCase
12-22-2003 05:29:31
 Re: tire swaping in reply to SLIDER, 12-20-2003 12:00:02
assuming they're 15x38's Rear tire isn't too bad for 2 healthy guys IF!!! its not loaded with fluid. If they're like the 730's you can slide them off the axle. IF they are loaded you may want to look at taking the fluid out and then tackling it. ALso take off any wheel weights 1st.. Where is this diesel?
