Common problems with Case torque converter drive
David Martella
12-20-2003 07:46:27
I have a case 420b with a torque converter drive and shuttle transmission. When I got the tractor the controls were frozen and the tractor would hardly move backward and forward. I am currently overhauling the transmission and was wondering what to look for regarding problems encountered with the torque converter drive.
Thanks
Jim B.
12-24-2003 15:02:42
 Re: Common problems with Case torque converter dri in reply to David Martella, 12-20-2003 07:46:27
David, I had to rebuild the Converter and Lock-Up clutch on my 800D COM years ago because it also would never totally disengage. Splitting the Tractor is the most difficult task, without all the overhead floating chainfalls and concrete floors that a dealer has. Mine required the normal through cleaning with new seals & gaskets. The only parts that showed any wear were the lock-up clutch plates, they were only slightly warped & discolored and I'm sure caused the clutch to drag and therefore not disengage. Converter itself was perfect. Operation has been OK since. Now the same is needed for a recently purchased 830 COM.
Tom Keehan
12-20-2003 09:46:31
I have a 420B also and the torque converter never totally disengages. I have to go straight from forward to reverse with no stopping in netural.I haven't the nerve to get into splitting the tractor and working on that converter. I am hope that you keep me up dated on how it goes. I wish you luck, you are braver than I am.
David Martella
12-21-2003 08:04:07
 Re: Re: Common problems with Case torque converter in reply to Tom Keehan, 12-20-2003 09:46:31
Hopefully there are others that have experienced similar problems with the Caseomatic and would share their thoughts on resolving them!
