Ferrules
Les...fortunate
12-20-2003 05:38:39
I let the dealership talk me into ordering new ferrules along with my manifold gaskets. Well, the new ones don't look anything like the old ones (which appear to be just fine). The old ones are a couple inches long and kind of like a funnel that sticks into the engine. The new ones resemble flat wedding rings and don't even fit tightly into their holes. Any thoughts on this situation?
jal-SD
12-21-2003 10:45:13
 Re: Ferrules in reply to Les...fortunate, 12-20-2003 05:38:39
Les, don't send 'em back. Found an SI we're gonna work on & it needs a new manifold. I'll take 'em off your hands for that one as we've got a mainifold, but are out of ferrules. Contact ya after we get back from our Nevada/California trip & we'll make arrangements for pay, shipping, etc. (My $0.02 worth. jal-SD)
Les...Uh-oh...Mike Schott
12-20-2003 05:46:42
I just looked at the archives and I see that the ones that were in it must be "venturi" for a multifuel engine. Well, I'm pretty sure that Sky already has it back together using the venturi(s). Will this cause a problem? Should I take them out and put the ferrules in? This tractor didn't have two fuel tanks but the manifold that was on it had a flipper which made me think that it had been made for dual fuel. Now I'm quite sure that was the case (no pun intended).
Mike Schotte
12-20-2003 06:27:02
 Re: Re: Ferrules in reply to Les...Uh-oh...Mike Schott, 12-20-2003 05:46:42
Hey Les,
You should be fine with the gas ferrules... (I think)
I've got a set of venturis from my '45 with the ruined manifold... but I was planning to hold onto 'em.
Are you still using the dual-fuel manifold, or did you switch to the gasoline manifold? Usually the kero ones are so far gone- I think people usually switch them over...
-Mike
Les
12-20-2003 07:58:24
 Re: Re: Re: Ferrules in reply to Mike Schotte, 12-20-2003 06:27:02
The old manifold was junk. The one I have now is gas only. But Sky has it back together with the venturis in it. Should we take them out and put the ferrules in? Will it make a difference? If so, what difference?
Mike Schotte
12-20-2003 08:31:07
 Re: Re: Re: Re: Ferrules in reply to Les, 12-20-2003 07:58:24
RobertTX thought it would be O.K.
Les...fortunate
12-20-2003 09:02:25
 Re: Re: Re: Re: Re: Ferrules in reply to Mike Schotte, 12-20-2003 08:31:07
Guess we might as well leave them in there then. Suppose I could get my money back on them ferrules? They weren't cheap. ";^)
Mike Schotte
12-20-2003 11:13:50
 Re: Re: Re: Re: Re: Re: Ferrules in reply to Les...fortunate, 12-20-2003 09:02:25
You could put 'em in my stocking... (grin)
How much were they?
Les...fortunate
12-20-2003 13:09:58
 Re: Re: Re: Re: Re: Re: Re: Ferrules in reply to Mike Schotte, 12-20-2003 11:13:50
Just under $14 each. You really want them?
Paul f
12-20-2003 13:46:13
 Re: Re: Re: Re: Re: Re: Re: Re: Ferrules in reply to Les...fortunate, 12-20-2003 13:09:58
Les: I'll buy them if you think they would fit a DC??
Manual shows part # O9813AB(4) and O886AB (2)
Les...fortunate
12-20-2003 15:20:29
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Ferrules in reply to Paul f, 12-20-2003 13:46:13
Number on the bill is CAS A26927. Must be different for a DC I would think?
Oops...
12-20-2003 06:28:23
I really should try to get more sleep at night...
