Need help L case paint code????????
Mike
12-19-2003 16:05:00
I cant find the paint code for the gray case's and what red did thay use on wheels I have a 35 l case i want to re paint some say farmall dark gray others light gray Help!!!!! !!!!!1
Dave Olson
12-20-2003 18:12:39
 Re: Need help L case paint code???????? in reply to Mike, 12-19-2003 16:05:00
third party image
I bought this Model C last year.
Here is the formula that the fellow said that they used to paint it back in '95.
DAR 32465 One quart formula: DMR-411 3, DMR 441 11, DMR 486 141, DMR 400 231, DMR 490 456, DMR 495 476, DMR 499 1036.
Hope this means something to someone! :) I like the color of my little C. Guess they didn't like red wheels!
Dave Olson - East-Central Illinois
Brian in Ohio
12-19-2003 21:21:46
If it is any help, the Case part number for L and C grey is B-13017. If you check around to some of the Case dealers, you can still get it. I found 5 gallon at a dealership once, and bought out the whole supply. As far as the red goes, I painted the wheels on mine with IHC Red. It's a close enough match to the original, although, some say that the original red was a little darker than that.
Farmall grey is the wrong shade. Case grey has a green tint in it that makes it different.
Mike
12-20-2003 04:45:35
 Re: Re: Need help L case paint code???????? in reply to Brian in Ohio, 12-19-2003 21:21:46
Thanks I have tried that but my dealer does not have it can the # be crossed overto a dupont or ppg tractor supply or even van sickel?
Brian in Ohio
12-20-2003 08:01:39
 Re: Re: Re: Need help L case paint code???????? in reply to Mike, 12-20-2003 04:45:35
I found the following in the archives, maybe it will be a help...
The codes for PPG #71282C are
D700 560.2
D721 1031.9
D723 1069.8
Brian in Ohio
12-20-2003 07:56:06
I believe there is a DuPont code, but I've never had to have it mixed, so I'm not sure what it is. If you ask Don LIvingston, ( Don L. on here ), he may know it. It probably had it mixed when he repainted his Crossmotor.
