modern seal list for SC's
Kent Fedor
12-19-2003 06:25:23
Modern replacement seal list for pre- eagle hitch Case SC tractors.
These are current-production modern seal numbers, that can be ordered through any reliable seal supply co. These seals worked on my �43 SC, so I believe the same would work on all pre- eagle hitch tractors, however since there could have been production changes I don�t know about, I am not liable if they don�t fit. Hopefully this will keep your old Case SC from slobbering oil. List compiled by Kent Fedor. E-mail: [email protected]
Axle outer seal (replaces felt)
National 413248
Axle inner seal, and also used for brake seals
National 415458
Belt pulley shaft seal
National 474264
Transmission front input shaft seal
National 473215
Clutch lever pivot shaft seal (fits in bell housing) National 350909
PTO shaft seal (for pto shaft that is �1 3/8")
National 472185
Front engine crankshaft
National 471763 (use two back-to-back to replace old thicker seal).
Mag/governor drive seal
(chicago rawhide) CR 6935
george md
12-19-2003 09:18:11
 Re: modern seal list for SC's in reply to Kent Fedor, 12-19-2003 06:25:23
Kent,
National seal publication # 517 has the list
of bearings and seals for ag tractors and machinery
george
Mike Schotte
12-19-2003 07:38:52
I'm going to add the original Case seal part numbers to Kent's list- (so we can know what new number replaces what old number) but I haven't gotten around to doing it yet.
Thanks again, Kent.
-Schotte
