Value of case backhoe 310-B
Richard Wolford
06-06-1999 07:56:57
Can anyone tell me the value and year of this backhoe. Engine appears to run fine. one stinger leaks hydraulic fluid. Owners want $2500. How hard is it to fine parts? Rick
Jeff King
06-11-1999 20:25:31
 Re: Value of case backhoe 310-B in reply to Richard Wolford, 06-06-1999 07:56:57
$2500 would be a fair price for the machine as you have described it. Is oil pressure OK? Should be between 15 and 20 PSI hot. Is compression good in all cylinders? Should be at least 130 psi in all four. Does clutch lock up solid? Have you checked all fluid levels in trans/rear differential and torque tube and refilled to verify no bad seals? I bought a G310W loader, seemed to be OK. Refilled the trans and torque tube to specifications and promptly oiled down the clutch. Now have to break down and replace seals and possibly bearings.
Regards
Jeff King
don
06-06-1999 18:40:30
I have a case model 320 gas with part of the loader.this would interchangeable with yours.I am looking to parts this out or complete.
