Vehicle Dynamics 101: The term "Toe-In" is the amount of inboard alignment the steering wheels, left & right, are adjusted at the front as viewed from the top (or bottom). This alignment spec affects the ability of the vehicle to still steer straight without driver input. In-other-words ...�Track Straight�. Normally, this is only a small amount, about 1/8� to 1/4� depending on the vehicle speed and usage. Toe-In is not usually adjustable on narrow front tractors but is adjustable on wide front tractors. The tractor spec is much greater than on-road vehicles because a farm vehicle max speed is about 20-25 MPH. The �Tip-Out� at the top is called Camber and is not usually adjustable on low-speed/off road vehicles. Camber provides much improved traction from a given tire size and tread because it causes the tires to tend to drive into each other. Therefore, the vehicle turns better without sliding the tires sideways while turning. Camber can be adjusted both positive and negative from vertical depending on the usage of the road vehicle. Have you ever noticed that when a road grader is pulling a load on an unleveled surface (ditching) the operator can remotely adjust Camber making the steering wheels vertical even though the whole machine is tipped into the ditch? This is so he can still steer against gravity and the �draft� of the grader blade. Most independent rear suspension vehicles even provide Camber adjustment on the rear wheels. No matter if it is front or rear wheel drive. Camber is predetermined and welded permanent on solid rear axles for trucks and trailers. It�s extreme Camber adjustments that race cars use to make the car try to always go left on a race track. Left and right side tires are even OD sized differently, called �stagger�, to make the bigger tire on the outside of the race track, again to use less horsepower to make the car go left. The last alignment spec is called Caster. That�s the amount of forward-tip at the top of the �king-pin� or axis between upper and lower ball joints, as related to the spindle position. This causes the steering wheels to return-to-center when the steering wheel is released after a turn. The same as a simple �caster wheel� on a grocery cart. Perhaps too many words > but I couldn�t stop myself , sorry!
