replacing head on a DC
Steve Butram
12-17-2003 11:03:34
What is the torque spec on the head bolts and What the valve tappet clearance? I just had the vales ground and need to put the head back on Thanks Steve
Paul f
12-17-2003 11:35:11
 Re: replacing head on a DC in reply to Steve Butram, 12-17-2003 11:03:34
Steve
75 ft-lbs
(Sequence starts in center then works outward alternating sides and ends)
Valves at .018 (cold)
Klyde
12-17-2003 18:03:44
 Re: Re: replacing head on a DC in reply to Paul f, 12-17-2003 11:35:11
Always wondered what happened to the feeler gauge that CAME with all the letter series tractors that was the correct thickness bent in an L shape and hanging on the rocker arm stud under the valve cover??? Did everybody throw them away???
joecool
12-17-2003 18:40:14
 Re: Re: Re: replacing head on a DC in reply to Klyde, 12-17-2003 18:03:44
we still a few of those fancy gauges. One came with the cc when my granddad bought it new and it stays under valve cover where it is supposed tobe.
Steve
12-17-2003 17:48:25
Thanks Paul I recently started working on the DC after I finished a 48 cub.It may be time to buy a manual. Thanks Steve
