Case 930 H2O in HYD
Nate
12-17-2003 08:42:55
My case 930 continues to have water in the hydraulic fluid. I've drained the fluid twice and still have'nt gotten it all out. The second time I even put it inside and thawed it out with a salamander heater. When the temp drops The water freezes and no hyd. I use this tractor everyday in the winter. Is there anything I can do to keep it from freezing up or and area thats prone to leaks where the water might be getting in.
Jens Andersen, Denmark
12-17-2003 11:32:01
 Re: Case 930 H2O in HYD in reply to Nate, 12-17-2003 08:42:55
I have worked with several different brands of
old tractors (Porsche, Holder, Agria, Case, Farmall), and on transmissions where the levers
are going in from the top and there is a bad "rubbergasket" around it, that is where the water is most likely to enter the transmission everytime you wash it or it sits out in the rain.
So check your "rubber"
Best wishes, Denmark
