SC problems
Joel
12-16-2003 19:57:32
I recently bought a 1944 SC that was running fairly well at the auction, now is only on one cylinder. New magneto has good spark at all 4 plugs. 2 plugs seemed dry when I pulled them out to check, so I thought the intake valves may not be functioning correctly. I pulled the cover and the pushrods are all tight against the rocker arms, and the arms are tight against all the valves. So obviously they need adjustment, even if that is not my problem. I have not checked the compression, but there is not much smoke when it runs. Several people said it "jumped time" and needs to be timed again, but I don't think that could happen if the mag is tight? Also, now that it is only on one cylinder the generator may not be spinning fast enough to charge the battery, the new ampmeter I put on it now shows zero. If you could help I would appreciate it. I don't want to turn around and sell it before I can at least rake some hay this summer!
1. How to adjust the valves? Which is exhaust and which is intake? What clearance?
2. How to check compression? Should I jack up the rear of the tractor and spin the tires by hand to move the cylinders, or do you just spin the starter with the ignition in "off position"?
3. Anything else that can cause an immediate loss of 3 cylinders? Thanks for the help. This is my first CASE and I'm still getting used to VERTICAL pistons, and 4 nonetheless!
John S. read the problem
12-18-2003 18:38:58
 Re: SC problems in reply to Joel, 12-16-2003 19:57:32
Ok here is something else. Did it start running bad when you connected the ammeter? Or was it fine for a while then started running bad. Just for grins though if you magnito has a coupler it may be wore out. Try turning your magnito 180 out at the coupler. (the two bolt spot) If by some chance it did jump it would have jumped 180 exactly. Which would explain good spark but no change in motor except for #2 is removed. If I am correct the timing should be 1-3-4-2. hence it is posible to only be firing the #2 at the right time and the others would be off kilter.
John S
12-17-2003 17:01:03
Ok first off... A dry plug is a good plug. Are You sure its running on one cylinder. Thats hard to imagine. Two cylinders mabey, not one. Ok now first lets see what cylinder/'s are dead. Try running the motor and with a well insulated set of pliers pull plug wires off one at a time. with them off listen for changes in the motor. If the motor it changes its good. If all four change then you worry about the valves. If its running you obviously have fuel. As far as the plugs go if the are dry you are ok. If they were wet then you would have a problem with them not firing. Try that then let us know!
Joel
12-18-2003 11:39:56
 Re: Re: SC problems in reply to John S, 12-17-2003 17:01:03
There is no engine change when I remove plugs 1,3,4 and the engine dies if I remove #2 wire. I am using Autolite plugs in it, correctly gapped and they have strong spark. I'll adjust valves and check compression. Thanks for the help!
John S.
12-18-2003 18:22:18
 Re: Re: Re: SC problems in reply to Joel , 12-18-2003 11:39:56
Hmmmm..... . This is new to me. I honestly have never seen a motor run on one cylinder. Unless like your friend told you that timing has jumped. I will have to think about this one..
Ok so now we know that 2 is working right because it runs on it. So the next thing I would look at is your magnito. Sounds like it may be a dying magnito at best. You can got to: >Link
hey>Link are a lot of articles there that will help with the magnito and worst case the valves.
Basically I am trying to say look for the easy stuff first. I would hate to see someone spend a couple of hours on valves and it be your magnito.
C. Amick
12-17-2003 09:28:26
The exhaust and intake valves are both set at 0.010" cold. The easiest way to adjust them is in the same order as the firing order stamped on the side of the engine block. You can tell a cylinder is on the compression stroke by putting your figure in the spark plug hole and having air blow out around it. With the piston all the way up both valves should be closed and the rocker arms should have 0.010" play in them. you can tell which valves are exhaust and intake by looking at your manifold. To check the compression, you should spin the engine using the starter and a compression tester. One way to turn the engine when adjusting valves, if you don't have a crank, is to put a socket on the belt pulley nut and turn the belt pulley with a ratchet. Get a set of Autolite spark plugs for it. I don't remember the Autolite number, but if you need it email me and I will lok it up..
G. L. Perry
12-17-2003 00:36:23
Champion spark plugs?? They foul easy, get some Autolite or Bosch, AC at least and try them. You sure there isn't nuts and nests in intake filter or manifold?? That happens alot when setting around. You can run with valve cover off and see if all are moving.
John Saeli
12-17-2003 04:54:21
 Re: Re: SC problems in reply to G. L. Perry, 12-17-2003 00:36:23
Hey G.L. A big AMEN to what you say about plugs!!
