John, Looks like you may have all you need but I spent a lot of time one finger typing it so here is. BTW mj I got this link from one of your posts last year, still have it in my favorites. Power Lift: Predecessor to the eagle hitch. High pressure hydraulic system. Piston pump driven by belt pulley drive, rated working pressure 4500 psi (1-2 gpm, can�t locate correct figure right now). Relief valve set 4350-4500 psi. Reservoir is part of belt pulley housing, about 2 qts. Working cylinder is single-acting 1-1/2� ID about 8� long mounted on the left side of torque tube opposite belt pulley. Cylinder actuates the lift via linkage and a retracting spring. Hyd control lever is mounted on right side of dash outboard the hand throttle. Eagle hitch: Introduced in 1948-49. Low pressure hydraulic system. Spur gear pump driven by engine cam gear, either directly or piggy-back on a magneto, rated working pressure 1000 psi, 7 gpm. Relief valve set (in depth control) set 900-1000 psi. Reservoir is torque tube, 8 qts. Working cylinder is single-acting, bolted to but integral with the rock shaft housing, under and just aft of the tractor seat. Draft arms are actuated by the rock shaft as it is rotated by the piston rod. Hyd control lever is mounted on the depth control unit attached to the right end of the rock shaft. The link is a modified high pressure lift. Noted that cylinder has been moved and chains are used in lieu of linkage. A very good idea if you are going to build one. I can�t find a good eagle hitch pix at the moment. Look at the posts below for F-I-T. Go to his site, click on VAC. Scroll down to the last tractor pix. The hump behind the seat is the piston housing bolted to the rock shaft. Control is to the right where that yellow is. The pump is on the right side of the engine mounted at the magneto opening. I can email pixs of mine if you need them. Joe
