pulling a SC in antique stock
pop
12-16-2003 16:03:47
I pull a sc in 4500 class at my local tractor show I compete with the red types which are able to move weight around to meet different track conditions which is hard with an SC because of all the cast iron, I do well the first day when track is hard but after they rut it up I do much worse have old hard tires 11.5 x 38 any body some idea? I know it is the wrong time of year but what the hay MERRY CHRISTMAS YOU ALL
C. Amick
12-17-2003 09:40:04
 Re: pulling a SC in antique stock in reply to pop, 12-16-2003 16:03:47
The SC seems to have a high weight to power ratio and ends up having to compete against tractors with 200 cubic inch plus engines. In addition to the domed pistons and a high compression head. You need to work at making the tractor lighter. Steel wheels instead of the cast iron ones, removing the weight that sits in front of the radiator, and wider tires may help. What might help depends upon the pulling rules.
DON L
12-17-2003 05:10:00
Using 3 11/16 domed pistons would be a big advantage over the early 3 1/2, and moderate advantage over a 3 5/8 set. Heads ending in 18 are low compression, and 17 if high compression. The hitch is a big thing also. Having a M in the 4500 class is bit like havin a fox in the hen house. Don L.
mike
12-16-2003 17:11:47
Make yourself and adjustable hitch. This hitch will allow you to hook the tractor in different conditions.You need to adjust in the vertical and hortizontal.
Example: if your front end is comming up, you can lower your hitch height, or move the hitch in.
Spinning out, move the hitch out untill you get a good balanced hook.
If this doesn't work build a great big engine!!
Jim M
12-16-2003 17:04:03
It all depends on the rules and what you want to spend and do to the SC.
