Intake valves
RoyG
12-15-2003 19:12:33
Does anyone know where I might find a set of intake valves for a Propane DC Head?
DKase
12-16-2003 05:58:48
 Re: Intake valves in reply to RoyG, 12-15-2003 19:12:33
When I put my propane head togather I used warn out 930 diesel valves. My local machine shop cut them down for length, and diameter, and cut the keeper notch in the right place for about $10.00 each. That was the only thing I could find that came close. Good Luck
Don Rudolph
12-15-2003 20:58:52
I was able to get one through my local engine shop. They went to a company that specializes in obsolete valves. It cost me 48.00 for one. They also could have machined one for me for about 60.00. They are shorter and slightly smaller and have a different keeper I believe. Good Luck!
CASEPOWER
12-15-2003 19:41:45
Roy, whats the difference between the LP and the reg.???
Thad
12-16-2003 04:08:13
 Re: Re: Intake valves in reply to CASEPOWER, 12-15-2003 19:41:45
The LP valves are longer because the floor of the combustion chamber is lower to raise the compresion. Thad
CASEPOWER
12-16-2003 05:31:11
 Re: Re: Re: Intake valves in reply to Thad, 12-16-2003 04:08:13
How much longer are they???
RoyG
12-16-2003 06:01:14
 Re: Re: Re: Re: Intake valves in reply to CASEPOWER, 12-16-2003 05:31:11
I will look and let you know. They are longer and the intake is bigger and they use a different keeper.
