VAC Project: Need some light switch help...
F-I-T
12-15-2003 18:03:46
third party image
I have misplaced my diagram that I drew when I de-wired the VAC. Then again, there was no telling if it was correct or not as wired.
Can anyone tell me which terminals go where? I have a resistor that was removed from the switch, and I have not yet decided if it is usable, but that's yet to check. Anyone know what value it is? I thought maybe I could wind a new one.
The only wiring diagram I can find in the parts book, and it leaves a lot to be desired.
Thanks for any help you can give this poor soul!
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
Joe (Wa)
12-15-2003 21:20:32
 Re: VAC Project: Need some light switch help... in reply to F-I-T, 12-15-2003 18:03:46
Frank, there are 2 types of generators: the cutout type & the automatic voltage regulator type. Your light switch is for the cutout type. Perhaps you can determine the value of the resistor, readout the switch and wire it per the following description from a Case manual.
GENERATOR (CUTOUT TYPE)
The generator is belt-driven, adjustable third brush type having a maximum cold output of approximately 12 amperes. The charging rate is adjusted by shifting the position of the third brush, which can be reached by removing the band on the rear end of the generator.
Amperage output is controlled by the light switch, which has three positions.
The first position (lights off) connects in the resistance and reduces generator output to 3 amperes.
The second position (lights off) allows full generator charge.
The third position (lights on) also allows full generator output.
Think about it, I know you can figure it out.
Joe
Alberta Mike
12-15-2003 19:59:45
Email me ... I have removed the hide feature from my email address so just hit the blue link. Assuming you still have an original 6V 3rd brush generator then I could go through the wiring with you by return email, probably tomorrow morning.
F-I-T
12-15-2003 20:27:09
 Re: Re: VAC Project: Need some light switch help. in reply to Alberta Mike, 12-15-2003 19:59:45
Thanks Mike.
I'll e-mail you now. I have an Autolite 6V Generator with a cut-out, so I believe it to be original.
I'll be able to shoot pictures to you as I go so that we get all the terminals pinned out. Might be helpful to the next guy, too!
Frank
John S
12-16-2003 17:44:44
 Re: Re: Re: VAC Project: Need some light switch h in reply to F-I-T, 12-15-2003 20:27:09
Lots of pics please.. I am going to have to do mine to. Mine is mising everything connected to the fuse holder looking thing too.
F-I-T
12-16-2003 18:44:11
 Re: Re: Re: Re: VAC Project: Need some light swit in reply to John S, 12-16-2003 17:44:44
John:
I'll be sure and post picures as soon as I can. Have to out of town (to LA) tomorrow through the 23rd, but hope to finish it up over Christmas. Mike sent me a very good description of the whole shebang, and Jim sent me some pictures of his original wiring, so when done, it ought to be easy enough to follow. Just be patient and I'll get it out.
Frank
Brandon
12-15-2003 19:08:51
I looked in the Operators Manual, and there isn't much of a Wiring Diagram there either. So, I can't help with the wiring. I just wanted to say that your various photos along the way are making me drool! Glad to see that your rear rims are working good. Can't wait to see the final product!
Gonna chain the VAC and the 70D drawbar to drawbar? I think it's a tossup to see which will win...heh heh
Are you gonna put any weight on the rear of the VAC? If you do any sort of pulling other than a brushhog, you will need it!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
John S.
12-15-2003 18:38:34
Agian FIT nice tractor work. I wish I could help you but mine has been messed with too. I will however look tomarrow and see if I have that resistor. I have a 46 VAC myself. I just got mine last week. My first Case!!!!
