My SC Smokes.........?
Kenneth Horneck
12-15-2003 09:53:15
I recently bought a late model SC Case. It has compression of at least 120 lbs. in each cylinder. I have straight 20w non-detergent oil in it. It runs good but smokes. It also has blow by coming from the crankcase breather. It had been sitting for at least two years. What do you think is causing the oil burning with such good compression? It has only been run an hour or so. Maybe more use will help. Could it be cracked oil rings? What would you do? Thanks, Ken
Tim Pennell
12-15-2003 22:25:04
 Re: My SC Smokes.........? in reply to Kenneth Horneck, 12-15-2003 09:53:15
A little trick..... .....
Warm the engine up then run a very small trickle of water from a garden hose into the carb, just enough that it is not a drip, barely running. Do this for 5 minutes. You will have to increase rpm a bit over idle in order to keep the engine running. The water turns to steam in the cylinders, cleans and expands rings somewhat and of course then goes out the exhaust. This will often loosen up stuck rings.
Tim
John S.
12-15-2003 18:31:38
Ok I will throw a little more knowledge I have learned through the years out. Being in salvage for many years here is what I do. First stop running it! You will take a chance of scoring the cylinder walls if something is stuck or worse rust! Anyways pull the spark plugs out fill cylinder with diesel and soak overnight. Diesel fuel has some great luricating and cleaning chemicals designed to help heavy duty engines. However these same lubricants are great for freeing up rings too. I do this on almost every motor I get that is stuck and have had no problems. Anyways in the morning turn the motor over without plugs to push everything the plug holes. Spray with WD40 or other lubricant and walla... Put the plugs back in and it should stop smoking after it warms up. Sometimes they get a little honory to start at first because of the diesel but once the gas is plentiful agian it will run agian. I hope this helps ya.
dctom
12-15-2003 17:28:21
HEY KEN, IF YOU CAN FIND A DYNO HANG HIM ON AND JUST PULL HIG GUTS OUT THAT WILL LOOSEN THE RINGS AND SMOKE WILL GO AWAY, WITH THAT KIND OF COMPRESSION OIL WIPERS MUST BE STUCK A LITTLE
todd hamilton
12-15-2003 18:56:21
 Re: Re: My SC Smokes.........? in reply to dctom, 12-15-2003 17:28:21
Or find some mature bushes that need to be pulled out - had mine warmed up enough one day to boil out the overflow on the radiator. It's a little tough on the clutch to do this.
Joe Smith
04-29-2005 13:45:46
 META HTTP-EQUIV=Refresh CONTENT= in reply to todd hamilton, 12-15-2003 18:56:21
<a href=http://pussy.matures-stories.com/>mature pussy</a>
Aberdale Farm
12-15-2003 16:41:21
My SC smoked too. It sat for many years without running. I suspect that the rings are sticking as mentioned in an earlier response. I removed the spark plugs and sprayed some PB blaster (penetrating oil) in the cylinder and let it set overnight. Then I ran it the next day. I did this 3 or 4 times and the smoking decreased. Don't know if its good or bad for the tractor, but the smoking has decreased. I run it more frequently now which seems to make a big difference.
Dale
John K
12-15-2003 14:54:25
How is you water temp, it the engine is running cold, the rings wont wear in proper. Did a 350 in a Trans Am and had the same problem, changed the thermostat and the problem cleared up after about 5 hours.
smokin SC aka todd hamilt
12-15-2003 14:44:20
My SC runs well but is a smoker - rings are not very good. However, the more I have run it, the smoking has decreased. I burn about one quart every two hours. For farming this would not be good. But for a play tractor $25.00 worth of oil gets me through a year of use - cannot justify the cost of an overhaul. 20W is pretty light. I have had good luck with Pennzoil straight 30W and I have just started using heavy duty Pennzoil 15W-40 for gas or diesel. I hear a little more noise in the valves but it helped the smoking. Get the engine good and hot to reseat the rings.
C. Amic k
12-15-2003 14:36:40
I figure the oil rings are stuck in the piston grooves. I had an SC with stuck oil rings and the more I ran it the worse it smoked. If the bearings are tight, I would pull the head and the oil pan, remove the pistons and hone the cylinders and put new rings in it.
Try some Nicorette?
12-15-2003 13:48:18
Sorry, but I just couldn't help myself with that title....
Since we know that the tractor is over 18 years old, I guess it's allowed to smoke if it wants to. (grin)
I've never had *anything* come out of the valve cover breather on my '49 SC. Is it possible that oil is leaking down past the valve guides and burning in the cylinder? What color is the smoke??
If it's only run an hour after sitting for two years- it might take a little longer for those rings to get reacquainted with the cylinder bores.
Maybe somebody else with more experience can help you further.
-Schotte
C. Amick
12-15-2003 14:38:40
 Re: Re: My SC Smokes.........? in reply to Try some Nicorette?, 12-15-2003 13:48:18
Mike, You're putting too much rum in your egg nog.:)
Brian in Ohio
12-15-2003 14:44:14
 Re: Re: Re: My SC Smokes.........? in reply to C. Amick, 12-15-2003 14:38:40
or not enough....
todd hamilton
12-15-2003 14:46:06
 Re: Re: Re: Re: My SC Smokes.........? in reply to Brian in Ohio, 12-15-2003 14:44:14
It's that beanless Texas chili - messes up your mind!:^)
