Axles Axles Axles
Stan(VA).
12-15-2003 04:29:46
Sorry, couldn't resist ;) ;)
Wondering if anybody would know axle sizes and some hub dimensions on the 3xx/4xx series row crop models? I see in the parts books they changed over at some point from 9/16" to 5/8" lug bolts on the 8 bolt hubs, but don't know the circle size or axle diameter.
Thanks,
Stan(VA).
Joe (Wa)
12-15-2003 17:12:27
 Re: Axles Axles Axles in reply to Stan(VA)., 12-15-2003 04:29:46
This is a '59 311b with 28" rims, 6 loops.
eight 9/16-18 bolts, 8" bolt circle.
axle 2-1/4".
Joe
Stan(VA).
12-15-2003 18:03:57
 Re: Re: Axles Axles Axles in reply to Joe (Wa), 12-15-2003 17:12:27
Thank you, Joe. That's exactly what I'm looking for, now just need to find a parts tractor.
Stan(VA).
Neil
12-15-2003 15:19:44
Stan,
I have a 430 and 200-B, I might could get what you need??
Neil
Stan(VA).
12-15-2003 16:06:19
 Re: Re: Axles Axles Axles in reply to Neil , 12-15-2003 15:19:44
Neil,
Sure. If either of your tractors has the row crop type axle with the sliding, clamp-on 8 bolt hub, that's what I'm looking for. (I think it usually was used with pressed steel wheels, and 4 loop 24" rims.) I need the axle diameter, and then the bolt circle diameter (center to center on two opposite of the 8 bolts) on the hub.
Thanks,
Stan(VA).
mike
12-15-2003 04:41:51
Stan, you still looking for a big 600 case?
Pete
12-16-2003 09:48:53
 Re: Re: Axles Axles Axles in reply to mike, 12-15-2003 04:41:51
I know of a guy looking for a gas model. I might be interest as well. Email me the info.
Pete.
Mike
12-16-2003 16:41:38
 Re: Re: Re: Axles Axles Axles in reply to Pete, 12-16-2003 09:48:53
I have a two 600 Lps ,and two dsls.I may be interested in selling .
One of the tractors is stuck, but i have a good 377 for that tractr.One of the LP's has a broken rod, the other LP runs, but needs work on the LP system. Email if you are interested.
Stan(VA).
12-15-2003 07:12:42
Didn't know I was looking for a 600 Case! Might have me confused with someone else? I'm normally over on the Farmall board, first time over here, a Case newby. I'm just hoping someone has a row crop 301/311/411/430/470 (at least, I'm not that familiar with case model num's) that can get some axle and hub measurements for me.
Thanks,
Stan(VA).
