VAC Project: We have Tires!!!!!!
F-I-T
12-14-2003 10:26:25
third party image
Now I can roll it inside, dry it off and wire it up!
mike
12-15-2003 09:28:49
 Re: VAC Project: We have Tires!!!!!! in reply to F-I-T, 12-14-2003 10:26:25
Very, nice. Its really taking shape.
curtis connaly
12-14-2003 22:10:19
hey great job on that vac . You make my vac look like a rust bucket ! hope i can get mine looking that good some day keep up the good work !
todd hamilton
12-14-2003 17:24:20
What did them tires cost? $50.00 each? (grin) :^) Tractor really looks nice!
F-I-T
12-14-2003 17:51:47
 Re: Re: VAC Project: We have Tires!!!!!! in reply to todd hamilton, 12-14-2003 17:24:20
Todd:
Never, never buy a tractor because it nice tires. I have spent far more on the rest of the tractor than a brand new set of tires for a better VAC would have cost!
Lesson learned: they sell new tires every day.
todd hamilton
12-14-2003 20:13:12
 Re: Re: Re: VAC Project: We have Tires!!!!!! in reply to F-I-T, 12-14-2003 17:51:47
Oh, I see! You went opposite of my plan. My SC was all painted nice when I bought it but the tires were rotten. One rear was patched with a piece of garden tractor tire. I played with it one winter to make sure it was going to run, then I bought tires. I gave $900.00 for the tractor and $632.00 for the tires!:^)
F-I-T
12-14-2003 20:43:21
 Re: Re: Re: Re: VAC Project: We have Tires!!!!!! in reply to todd hamilton, 12-14-2003 20:13:12
Your plan was MUCH better than mine!
Glenn FitzGerald
12-14-2003 17:03:09
BEAUTIFUL TRACTOR!...FIT, you do wonderful work! I suppose you said on an earlier post but just how much work did you have to do to the drive train? When I am all done I plan on having a fully restored show quality DC, SC and VAC. So far I have DC which I hope to get finished next summer, and I'm dealing on an SC now.
F-I-T
12-14-2003 18:06:22
 Re: Re: VAC Project: We have Tires!!!!!! in reply to Glenn FitzGerald, 12-14-2003 17:03:09
Glenn:
Here's a short list of the salvage parts I had to obtain: radiator, steering column and shaft, side shields, aircleaner assembly, manifold, dash assembly, original fuel cap, seat pan, and fuel tank. Then I bought a set of new rear rims, and all four inner tubes. I replaced the rings, rod bearings, main bearings, all roller and ball bearings from the torque tube, through the transmission, the axle bearings, PTO bearings, and any seals. The total for bearings was near $600 (Argh?!?!). In the cylinder head, I had to replace all the exhaust valves, one intake valve, all the springs and keepers, had hardened seats installed, valve grind, magnufluxed, and head planed for flatness. Head cost around $350 (Argh?!?!).
Other new stuff included filter for the hydraulics, oil filter, sediment bowel, carb kit, plugs, distributor kit, plug wires, gauges, engine gaskets, other gaskets, gasket paper for gaskets I couldn't get, transmission boot, gear shift knob, and vinyl-cut decals.
As far as the engine goes, the crank miked fine, just a bit worn, the piston grooves were fine. Had the crank polished to accept .022" rods, and honed the cylinders until smooth, and checked taper (it was fine).
Then about $300 in paint materials, and a lot of plinking and tapping and wwelding and filling and sanding and etc.
If I had a true total, I'd probably shoot myself!
Not really. The darn thin is turning out pretty cute!
Frank
John H-WI
12-14-2003 14:44:57
Frank, that thing is going to look too good to drive around. Just like a new car you won't want to get a scratch on it.
Fantastic job!!
Jerry
12-14-2003 11:26:35
Frank, It sure looks good. Did you ever find that hydraulic line ? If you have the old one I can get it made for you.
Jerry
F-I-T
12-14-2003 13:36:30
 Re: Re: VAC Project: We have Tires!!!!!! in reply to Jerry, 12-14-2003 11:26:35
Jerry:
I have a good "back-half". Still looking for the front half. I've been able to roll it inside now for the first time since July.
So, if anyone out there has a good high-pressure line from the engine hydro pump to the Eagle Hitch, or just the front half, I'm interested!
Frank
old
12-14-2003 11:17:04
Nice looking toy you have there, I wouldn't mine haveing one that looked that good
