SC Timing
Louie
12-13-2003 08:11:46
How do you time a bosch mag. to the engine on an SC case tractor
C. Amick
12-15-2003 10:03:16
 Re: SC Timing in reply to Louie, 12-13-2003 08:11:46
The mag is supposed to fire on cylinder No. 1 when the punch mark on the fly wheel is visible through the viewing hole in the bell housing on the right side of the tractor. There is a threaded pipe plug that must be removed to see it. You will have to remove No.1 spark plug and hold your finger over the hole to make sure it is coming up on compression. You should be able to pull the mag out and keep rotating it until you get it right.
