difference between 3294 and 3394
zoidberg
12-12-2003 15:03:08
3294 or 3394. Can anyone tell me the difference between the two models. They look like the same thing with different numbers. Any help is much appreciated. thanks
doug@upr
12-12-2003 17:23:07
 Re: difference between 3294 and 3394 in reply to zoidberg, 12-12-2003 15:03:08
the 3294 is basically a juiced up 2290-2294, except the 3294 tractors were all equipped with fwa, either a zf or carraro axle (the carraro axle is a much more reliable axle, though not as sharp turning). also the 3294 was only equipped with 1000 pto, though many have been converted to dual pto since a pto would easily convert over from a 20-2290,94. the 3394 is basically the same tractor tractor design way back to the 12-1370 tractor with some minor upgrades up through the 90 & 94 series. the only real difference from the 90 to the 94 series is the electronic control powershift, which made for a much more reliable trans, since i was not as easy to abuse.
also the 94 series had the option of a 24 speed powershift, and a dual pto is not available for these tractors.
almost forgot, even though both tractors have the 504 case motor and maybe pumping out the same horsepower, the 3394 has a much larger journal crankshaft, believe it or not but the 3294 has the same crankshaft that was used way back to the 930-1030 era.
turbo
12-12-2003 15:50:50
Look at them from the rear. Only the cab, engine and hood are the same. From the flywheel back they are totally different. The 3294 has the small rear frame with a 2 pinion differential that was used in the 20, 2294. It came with the front tires filled with ballast from the factory and the front axle had no disconnect box. The 3394 had the large rear frame with a 3 pinion differential that began with the 12-1370 and was used in the 2390 and 2394. It was optional with a 24 speed power shift. The 3594 used the large rear frame and a 4 pinion differential.
