simms injector pump
zach
12-11-2003 17:34:09
can any one help me with a simms injector pump, no fuel going to #3 cyl. Injector OK . This is on a case 1214. Thank You Zach
JCMarleau
12-13-2003 08:53:10
 Re: simms injector pump in reply to zach, 12-11-2003 17:34:09
If too costly to repair i have one pump my e mail is [email protected]
kyhayman
12-12-2003 07:03:13
Sounds like a lobe worn off of pump cam on #3. I've had to have several Simms pumps rebuilt over the years and invariably if I had to have work done in the cam box it was #3.
Last one I had done was $900.
Regards,
David
SheldonMT
12-11-2003 18:14:52
Simms are famous for problems, for fact that no one services the pump itself. the pump is not oiled by the engine but by self contained oil which should be serviced every time the engine oil is changed. SO if you have not serviced the pump this is most likely the trouble and will have to bit the bullet and have it rebuilt. If it is real bad the pump sometimes are none rebuildable. Sooo Sorry but this is from experiance. SheldonMT
