Serial Number
Henry Parker
12-11-2003 09:09:14
I'm new at this collecting of tractors I just got a Case SC given to me and it does not have an ID plate and the serial # is not on the engine block flang my question is there any other way of knowing what year it was made. I'm lucky it was stuck but I have it apart now and every thing looks good. It is all there but the tag and it has a bosch mag. which I don't thing is right. Any help would be appreciated. thanks and merry christmas.
dctom
12-11-2003 10:36:51
 Re: Serial Number in reply to Henry Parker, 12-11-2003 09:09:14
HENERY; IF THE SR # IS NOT ON THE ENGINE FLANGE RIGHT BEHIND THE AIR FILTER, THAN THERE IS NO WAY OF KNOWING THE YEAR FOR SURE, CASE DID USE BOSCH MAGS ON THE SC THE FIRST YEAR OR SO SO IT THAT IS WHAT YOU HAVE IT COULD BE A 41 OR A 42 CHECK THE ENGINE FLANGE DCTOM
Tom Railsback
12-11-2003 15:33:43
 Re: Re: Serial Number in reply to dctom, 12-11-2003 10:36:51
Is it possible to get within a couple of years using the date the transmission case was cast? As
I recall that can be found on the very bottom of the case to the side of where the drawbar bolts on.
It should be fairly accurate for earlier production tractors, at least as far as the year goes.
Henry Parker
12-11-2003 12:57:52
Thanks DCTom if it is on the flange i can't find it and I have sanded and looked several times but I don't see it. That mag is a bosch U4 and it is not flange mounted it has been motified with a base plate mount. hey thanks a lot for the info as you can see I am real green on this
